[Qgis-user] Coordinates from wgs84 utm /expressed in meter) to wgs84 (expressed in degrees)
    C Hamilton
    adenaculture at gmail.com
    Thu Mar 21 06:10:24 PDT 2019
The Lat Lon Tools plugin does this conversion to put the coordinates into
one or two fields. See "Plugins->Lat Lon Tools->Conversions->Point layer to
fields". It has a lot of flexibility as to the output format.
Calvin
On Thu, Mar 21, 2019 at 3:06 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Wed, 20 Mar 2019 at 03:55, Azzurra Lentini
> <lentini.azzurra at polymtl.ca> wrote:
> > Good morning,
> > if for example my project is in this referencing system: WGS84-UTM,
> > when I ask to calculate the coordinates Y and X (with field calculator
> > - geometry), it will produce the coordinates in meters.
> > But what can I do if I want the same coordinates in degrees?
> > (obviously in the same datum wgs84)
> I think this is a common enough task to warrant it's own processing
> algorithm. I've added one in https://github.com/qgis/QGIS/pull/9587
> (so will be in 3.8), ported from some Python code I used at a
> customer's workplace.
> Nyall
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190321/8613d2f6/attachment.html>
