[Qgis-user] Interesting anomaly with the snapping toolbar
DelazJ delazj at gmail.com
Thu Mar 21 09:58:37 PDT 2019
Hi Tyler,
It's not a bug. A 3.0 feature that may not look obvious at first sight.
This button indicates the advanced configuration, hence those tools are
hidden since they are enabled on a layer basis. Press that icon and select
the "Open snapping Options..." at the bottom of the drop-down menu and you
get a dialog with the options available.
Pressing that icon also allows you to switch to the "all layers" or "active
layer" configurations which both show the tools you are missing.
Do not forget that snapping is a project property, reason why the configs
of this file is propagated to files that derived from it.
Regards,
Harrissou
Le jeu. 21 mars 2019 à 17:10, Tyler Veinot <tylerkveinot at gmail.com> a
écrit :
> Hi All;
> I have one map document that when I open it my snapping toolbar changes
> from this...
> [image: image.png]
> To this...
> [image: image.png]
> See how the settings for layer and snap to/tolerance disappeared?
> It only seems to happen with one specific map document and any document
> created from it as a base. I tried looking for a setting I might have in my
> document that would change the snapping tool bar but couldn't find
> anything. Has anyone else had this issue? Is it a something I can fix or is
> it a corruption of the map document file.
> Thanks;
> Tyler
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190321/76ab9ca7/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190321/76ab9ca7/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190321/76ab9ca7/attachment-0001.png>
