[Qgis-user] Interesting anomaly with the snapping toolbar
Tyler Veinot
tylerkveinot at gmail.com
Thu Mar 21 10:25:41 PDT 2019
Thanks, That got it!
On Thu, Mar 21, 2019 at 1:58 PM DelazJ <delazj at gmail.com> wrote:
> Hi Tyler,
> It's not a bug. A 3.0 feature that may not look obvious at first sight.
> This button indicates the advanced configuration, hence those tools are
> hidden since they are enabled on a layer basis. Press that icon and select
> the "Open snapping Options..." at the bottom of the drop-down menu and you
> get a dialog with the options available.
> Pressing that icon also allows you to switch to the "all layers" or
> "active layer" configurations which both show the tools you are missing.
> Do not forget that snapping is a project property, reason why the configs
> of this file is propagated to files that derived from it.
> Regards,
> Harrissou
> Le jeu. 21 mars 2019 à 17:10, Tyler Veinot <tylerkveinot at gmail.com> a
> écrit :
>> Hi All;
>> I have one map document that when I open it my snapping toolbar changes
>> from this...
>> [image: image.png]
>> To this...
>> [image: image.png]
>> See how the settings for layer and snap to/tolerance disappeared?
>> It only seems to happen with one specific map document and any document
>> created from it as a base. I tried looking for a setting I might have in my
>> document that would change the snapping tool bar but couldn't find
>> anything. Has anyone else had this issue? Is it a something I can fix or is
>> it a corruption of the map document file.
>> Thanks;
>> Tyler
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190321/0eeb039f/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190321/0eeb039f/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190321/0eeb039f/attachment-0001.png>
