[Qgis-user] Rasterize from non-numeric fields
    Richard McDonnell
    richard.mcdonnell at opw.ie
    Tue Mar 26 02:52:19 PDT 2019
The easiest way is to create a raster field, you use it to give classification values for each vector feature. For example,
1.      Grass
2.      Water
3.      Urban
4.      …etc…
You can then select this attribute as the field to be rasterised.
Hope this helps.
Regards,
Richard.
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Chailloux Mathieu
Sent: 26 March 2019 08:09
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Rasterize from non-numeric fields
Hi all,
Is there a way to rasterize a vector layer and burn values from a non-numeric fields ?
For instance let's say I have a land cover layer with a string description for each class.
I would like to rasterize such field without creating manually a new one.
I would imagine some feature generating integers for each class/value with such value/integer association and rasterized layer as outputs.
I guess some SQL request could do it but I would like to have it directly in QGIS.
Regards,
Mathieu
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190326/6bf5bb07/attachment.html>
