[Qgis-user] Atlas by year
    Andreas Neumann
    a.neumann at carto.net
    Tue Mar 26 05:46:24 PDT 2019
Atlas with combinations of two or more attributes, and/or sometimes also
feature geometries - this is a typical case for a cross-join in a
database. You would create a new view as a cross-join with all
combinations.
But glad that you already found a solution.
Greetings,
Andreas
On 2019-03-26 13:43, Marco Antônio Ferreira Pedrosa wrote:
> Hi Alexandre,
> It worked perfectly! As you said:
> 1) I made a unique list from the years and generate a new feature. Then used it as the coverage layer for atlas.
> 2) For each symboloy (rule-based):
> (@atlas_pagename  =  "Year") AND ("Quality" = 'Excelent')
> (@atlas_pagename  =   "Year"  ) AND ("Quality" = 'Good')
> so on...
> As you see I changed it a little bit, so I can use the "current" year from Atlas.
> Tnks a lot!
> P.S: PORTUGAL CARALHO!!!! (sou Brasileiro haha)
> Marcão
> Em seg, 25 de mar de 2019 às 20:58, Alexandre Neto <senhor.neto at gmail.com> escreveu: You need to create a layer, with a column called year, with each year in a row. The layer does not need to have a geometry. Use that layer as the coverage layer for atlas.
> For the layer you want to filter by year, create a rule-based symbology, and use the following rule/expression:
> attribute(@atlasfeature, 'yea
> r') = "year"
> This compares the current atlas feature field year, to the layer year column, and renders the features only if the years match.
> Hope it helps.
> Alexandre Neto
> A seg, 25/03/2019, 13:50, Marco Antônio Ferreira Pedrosa <marcomottim at gmail.com> escreveu:
> Hi all,
> Sorry if s a silly question!
> How to generate an atlas by a value in the attibute table? (i.e: Year). QGIS Atlas would generate one map for each attribute value but not group by year.
> For each year, I want to show the features with a categorized symbology (same for all years, but I want to show just the features from that year).
> tnks in advance! _______________________________________________
> Qgis-user mailing list
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user --
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190326/7b07fb77/attachment.html>
