[Qgis-user] Atlas by year
Marco Antônio Ferreira Pedrosa
marcomottim at gmail.com
Tue Mar 26 05:56:37 PDT 2019
Hi Andreas,
How can I create and use a cross-join in this case? (I think it would be
useful for the other tasks that I have to work on)
Tnks in advance.
Marcão
Em ter, 26 de mar de 2019 às 09:46, Andreas Neumann <a.neumann at carto.net>
escreveu:
> Hi,
> Atlas with combinations of two or more attributes, and/or sometimes also
> feature geometries - this is a typical case for a cross-join in a database.
> You would create a new view as a cross-join with all combinations.
> But glad that you already found a solution.
> Greetings,
> Andreas
> On 2019-03-26 13:43, Marco Antônio Ferreira Pedrosa wrote:
> Hi Alexandre,
> It worked perfectly! As you said:
> 1) I made a unique list from the years and generate a new feature. Then
> used it as the coverage layer for atlas.
> 2) For each symboloy (rule-based):
> (@atlas_pagename = "Year") AND ("Quality" = 'Excelent')
> (@atlas_pagename = "Year" ) AND ("Quality" = 'Good')
> so on...
> As you see I changed it a little bit, so I can use the "current" year from
> Atlas.
> Tnks a lot!
> P.S: PORTUGAL CARALHO!!!! (sou Brasileiro haha)
> Marcão
> Em seg, 25 de mar de 2019 às 20:58, Alexandre Neto <senhor.neto at gmail.com>
> escreveu:
>> You need to create a layer, with a column called year, with each year in
>> a row. The layer does not need to have a geometry. Use that layer as the
>> For the layer you want to filter by year, create a rule-based symbology,
>> and use the following rule/expression:
>> attribute(@atlasfeature, 'yea
>> r') = "year"
>> This compares the current atlas feature field year, to the layer year
>> column, and renders the features only if the years match.
>> Hope it helps.
>> Alexandre Neto
>> A seg, 25/03/2019, 13:50, Marco Antônio Ferreira Pedrosa <
>> marcomottim at gmail.com> escreveu:
>>> Hi all,
>>> Sorry if s a silly question!
>>> How to generate an atlas by a value in the attibute table? (i.e: Year).
>>> QGIS Atlas would generate one map for each attribute value but not group by
>>> year.
>>> For each year, I want to show the features with a categorized symbology
>>> (same for all years, but I want to show just the features from that year).
>>> tnks in advance!
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190326/3402bca8/attachment.html>
