[Qgis-user] Edit raster (DEM) values with polygon
    Doug Johnston
    rivers.creeks at gmail.com
    Tue Mar 26 13:21:03 PDT 2019
Hello all.
I am attempting to edit (change) the values for all pixels in a DEM in
region of the DEM.
The real-world problem is I want to burn in a proposed flood wall/dike into
an existing DEM.
I have a polygon with the desired elevation field, and I also have a raster
with the desired elevation values (rasterized from the polygon).
I have looked at rasterize tool, however cannot find the correct way burn
the overlying polygon into the dem (referencing an attribute field), or if
it is even possible.
I would also think raster calculator would do it with the two rasters, but
I do not have the syntax down:
pseudo-code: if dike-dem is_not "no_data" |> use dike-dem; else use
original-DEM.
Here is a screen shot of the two rasters.
All help is appreciated; thanks in advance.
Doug Johnston
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190326/1dbc02d5/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190326/1dbc02d5/attachment.jpe>
