[Qgis-user] Atlas by year
Alexandre Neto
senhor.neto at gmail.com
Tue Mar 26 14:31:21 PDT 2019
Hi Andreas,
Last time I tried, virtual layers did not work as coverage layers. One
would need to export the layer before using it.
Do you confirm this?
Cheers,
Alex Neto
A ter, 26/03/2019, 13:21, Marco Antônio Ferreira Pedrosa <
marcomottim at gmail.com> escreveu:
> Hi Andreas,
> Thanks, it will be useful!!
> Best regards!
> Marcão
> skype: marco.afp
> Em ter, 26 de mar de 2019 às 10:14, Andreas Neumann <a.neumann at carto.net>
> escreveu:
>> Hi,
>> It would be a join without a where clause, but limiting to the attribute
>> columns that are relevant. See
>> http://www.sqlitetutorial.net/sqlite-cross-join/
>> You would have to create a new virtual table in QGIS for it. See
>> https://docs.qgis.org/3.4/en/docs/user_manual/managing_data_source/create_layers.html#creating-virtual-layers
>> After creating that new virtual layer you can use it as Atlas coverage
>> layer.
>> Greetings,
>> Andreas
>> On 2019-03-26 13:56, Marco Antônio Ferreira Pedrosa wrote:
>> Hi Andreas,
>> How can I create and use a cross-join in this case? (I think it would be
>> useful for the other tasks that I have to work on)
>> Tnks in advance.
>> Marcão
>> Em ter, 26 de mar de 2019 às 09:46, Andreas Neumann <a.neumann at carto.net>
>> escreveu:
>>> Hi,
>>> Atlas with combinations of two or more attributes, and/or sometimes also
>>> feature geometries - this is a typical case for a cross-join in a database.
>>> You would create a new view as a cross-join with all combinations.
>>> But glad that you already found a solution.
>>> Greetings,
>>> Andreas
>>> On 2019-03-26 13:43, Marco Antônio Ferreira Pedrosa wrote:
>>> Hi Alexandre,
>>> It worked perfectly! As you said:
>>> 1) I made a unique list from the years and generate a new feature. Then
>>> used it as the coverage layer for atlas.
>>> 2) For each symboloy (rule-based):
>>> (@atlas_pagename = "Year") AND ("Quality" = 'Excelent')
>>> (@atlas_pagename = "Year" ) AND ("Quality" = 'Good')
>>> so on...
>>> As you see I changed it a little bit, so I can use the "current" year
>>> from Atlas.
>>> Tnks a lot!
>>> P.S: PORTUGAL CARALHO!!!! (sou Brasileiro haha)
>>> Marcão
>>> Em seg, 25 de mar de 2019 às 20:58, Alexandre Neto <
>>> senhor.neto at gmail.com> escreveu:
>>>> You need to create a layer, with a column called year, with each year
>>>> in a row. The layer does not need to have a geometry. Use that layer as the
>>>> For the layer you want to filter by year, create a rule-based
>>>> symbology, and use the following rule/expression:
>>>> attribute(@atlasfeature, 'yea
>>>> r') = "year"
>>>> This compares the current atlas feature field year, to the layer year
>>>> column, and renders the features only if the years match.
>>>> Hope it helps.
>>>> Alexandre Neto
>>>> A seg, 25/03/2019, 13:50, Marco Antônio Ferreira Pedrosa <
>>>>> Hi all,
>>>>> Sorry if s a silly question!
>>>>> How to generate an atlas by a value in the attibute table? (i.e:
>>>>> Year). QGIS Atlas would generate one map for each attribute value but not
>>>>> group by year.
>>>>> For each year, I want to show the features with a categorized
>>>>> symbology (same for all years, but I want to show just the features from
>>>>> that year).
>>>>> tnks in advance!
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Alexandre Neto
>>>> @AlexNetoGeo
>>>> http://sigsemgrilhetas.wordpress.com
>>>> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190326/c52689dc/attachment.html>
