[Qgis-user] Atlas by year
    Marco Antônio Ferreira Pedrosa
    marcomottim at gmail.com
    Tue Mar 26 06:21:04 PDT 2019
Hi Andreas,
Thanks, it will be useful!!
Best regards!
Marcão
skype: marco.afp
Em ter, 26 de mar de 2019 às 10:14, Andreas Neumann <a.neumann at carto.net>
escreveu:
> Hi,
> It would be a join without a where clause, but limiting to the attribute
> columns that are relevant. See
> http://www.sqlitetutorial.net/sqlite-cross-join/
> You would have to create a new virtual table in QGIS for it. See
> https://docs.qgis.org/3.4/en/docs/user_manual/managing_data_source/create_layers.html#creating-virtual-layers
> After creating that new virtual layer you can use it as Atlas coverage
> layer.
> Greetings,
> Andreas
> On 2019-03-26 13:56, Marco Antônio Ferreira Pedrosa wrote:
> Hi Andreas,
> How can I create and use a cross-join in this case? (I think it would be
> useful for the other tasks that I have to work on)
> Tnks in advance.
> Marcão
> Em ter, 26 de mar de 2019 às 09:46, Andreas Neumann <a.neumann at carto.net>
> escreveu:
>> Hi,
>> Atlas with combinations of two or more attributes, and/or sometimes also
>> feature geometries - this is a typical case for a cross-join in a database.
>> You would create a new view as a cross-join with all combinations.
>> But glad that you already found a solution.
>> Greetings,
>> Andreas
>> On 2019-03-26 13:43, Marco Antônio Ferreira Pedrosa wrote:
>> Hi Alexandre,
>> It worked perfectly! As you said:
>> 1) I made a unique list from the years and generate a new feature. Then
>> used it as the coverage layer for atlas.
>> 2) For each symboloy (rule-based):
>>  (@atlas_pagename  =  "Year") AND ("Quality" = 'Excelent')
>>  (@atlas_pagename  =   "Year"  ) AND ("Quality" = 'Good')
>> so on...
>> As you see I changed it a little bit, so I can use the "current" year
>> from Atlas.
>> Tnks a lot!
>> P.S: PORTUGAL CARALHO!!!! (sou Brasileiro haha)
>> Marcão
>> Em seg, 25 de mar de 2019 às 20:58, Alexandre Neto <senhor.neto at gmail.com>
>> escreveu:
>>> You need to create a layer, with a column called year, with each year in
>>> a row. The layer does not need to have a geometry. Use that layer as the
>>> For the layer you want to filter by year, create a rule-based symbology,
>>> and use the following rule/expression:
>>> attribute(@atlasfeature, 'yea
>>> r') = "year"
>>> This compares the current atlas feature field year, to the layer year
>>> column, and renders the features only if the years match.
>>> Hope it helps.
>>> Alexandre Neto
>>> A seg, 25/03/2019, 13:50, Marco Antônio Ferreira Pedrosa <
>>> marcomottim at gmail.com> escreveu:
>>>> Hi all,
>>>> Sorry if s a silly question!
>>>> How to generate an atlas by a value in the attibute table? (i.e: Year).
>>>> QGIS Atlas would generate one map for each attribute value but not group by
>>>> year.
>>>> For each year, I want to show the features with a categorized symbology
>>>> (same for all years, but I want to show just the features from that year).
>>>> tnks in advance!
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Alexandre Neto
>>> @AlexNetoGeo
>>> http://sigsemgrilhetas.wordpress.com
>>> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190326/94f9aee3/attachment.html>
