[Qgis-user] error message when opening a project
    DelazJ
    delazj at gmail.com
    Sun May  5 16:17:33 PDT 2019
This line
* File "C:/Users/Celso/AppData/**Roaming/QGIS/QGIS3\profiles\*
*default/python/plugins\**qgiscloud\**qgiscloudplugindialog.py", line 808,
in __wkbTypeString*
points that the issue comes from qgiscloud plugin. So first, either
uninstall it or run qgis without plugins to confirm the origin. And report
the issue on the plugin repository in case the authors are not following
this list so they get it fixed.
Regards,
Harrissou
Le lun. 6 mai 2019 à 01:02, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
a écrit :
> Hi,
> I have no idea what this error is but my first reaction would be to
> uninstall QGIS and reinstall QGIS.  If that does not help, please add what
> version of QGIS you have, what installer you used and what operating system
> you are on.  I would add what version the projects are done with.  You
> could also disable all plugins that could be at the root of the problem.
> That would help others figure things out.
> Good luck,
> Nicolas
> Le 5 mai 2019 à 10:20, Celso Catelani <cscatelani at gmail.com> a écrit :
> Hi,
> I'm receiving an error message in all projects i try to open, saying the
> follow:
> type object 'Qgis' has no attribute 'WkbUnknown'
> Traceback (most recent call last):
> File
> "C:/Users/Celso/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\qgiscloudplugindialog.py",
> line 702, in update_local_layers
> self.update_local_data_sources(local_layers, local_raster_layers)
> File
> line 775, in update_local_data_sources
> "Unsupported geometry type '{type}' in layer
> '{layer}'").format(type=self.__wkbTypeString(wkbType),
> layer=layers[0].name()))
> File
> line 808, in __wkbTypeString
> if wkbType == Qgis.WkbUnknown:
> AttributeError: type object 'Qgis' has no attribute 'WkbUnknown'
> Please, may someone help me about this?
> Tanks a lot!!!!
>  Celso S. Catelani
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Livre
> de vírus. www.avast.com
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>.
> <#m_2851205939630208801_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190506/a861b9d0/attachment.html>
