[Qgis-user] error message when opening a project
Celso Catelani cscatelani at gmail.com
Mon May 13 02:44:39 PDT 2019
Thanks guys!!!!
I just uninstall the plugin and the respective problem was solved.
Best regards.
Prof. Dr. Celso de Souza Catelani
UNITAU/IPHABI
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Livre
de vírus. www.avast.com
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>.
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
On Sun, May 5, 2019, 20:17 DelazJ <delazj at gmail.com> wrote:
> Hi,
> This line
> * File "C:/Users/Celso/AppData/**Roaming/QGIS/QGIS3\profiles\*
> *default/python/plugins\**qgiscloud\**qgiscloudplugindialog.py", line
> 808, in __wkbTypeString*
> points that the issue comes from qgiscloud plugin. So first, either
> uninstall it or run qgis without plugins to confirm the origin. And report
> the issue on the plugin repository in case the authors are not following
> this list so they get it fixed.
> Regards,
> Harrissou
> Le lun. 6 mai 2019 à 01:02, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> a écrit :
>> Hi,
>> I have no idea what this error is but my first reaction would be to
>> uninstall QGIS and reinstall QGIS.  If that does not help, please add what
>> version of QGIS you have, what installer you used and what operating system
>> you are on.  I would add what version the projects are done with.  You
>> could also disable all plugins that could be at the root of the problem.
>> That would help others figure things out.
>> Good luck,
>> Nicolas
>> Le 5 mai 2019 à 10:20, Celso Catelani <cscatelani at gmail.com> a écrit :
>> Hi,
>> I'm receiving an error message in all projects i try to open, saying the
>> follow:
>> type object 'Qgis' has no attribute 'WkbUnknown'
>> Traceback (most recent call last):
>> File
>> "C:/Users/Celso/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\qgiscloudplugindialog.py",
>> line 702, in update_local_layers
>> self.update_local_data_sources(local_layers, local_raster_layers)
>> File
>> line 775, in update_local_data_sources
>> "Unsupported geometry type '{type}' in layer
>> '{layer}'").format(type=self.__wkbTypeString(wkbType),
>> layer=layers[0].name()))
>> File
>> line 808, in __wkbTypeString
>> if wkbType == Qgis.WkbUnknown:
>> AttributeError: type object 'Qgis' has no attribute 'WkbUnknown'
>> Please, may someone help me about this?
>> Tanks a lot!!!!
>>  Celso S. Catelani
>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Livre
>> <#m_-4493191515937090621_m_-5924173161429720625_m_2851205939630208801_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190513/55fd6b17/attachment.html>
