[Qgis-user] QGIS 6.3 for macOS 10.14.5 : HELP
    Nuno Manuel de Figueiredo de Santos Loureiro
    nlourei at ualg.pt
    Tue May 21 18:07:59 PDT 2019
Hi Ramon,
Many thanks.
I followed your recommendations.
However a few issues remain.
William wrotes:
/Library/Frameworks/Python.framework/Versions/3.6/bin:/Library/Frameworks/GDAL.framework/Versions/2.3/Programs:
in the step by step
But he also says that GDAL is 2.4 and not 2.3.
I checked in my computar and I have GDAL 1.11, 2.1, GDAL 2.2 and GDAL 2.4.
I believe that GDAL 1.11 and 2.1 is needed for QGIS 2.18.23, that GDAL 2.2 is not needed and that GDAL 2.4 is needed for QGIS 3.6.2.
Is this true?
After, I changed the above line to
/Library/Frameworks/Python.framework/Versions/3.6/bin:/Library/Frameworks/GDAL.framework/Versions/2.4/Programs:
(only 2.3 to 2.4)
Finally the Merge a few rasters works well ;-)
But the following step, the Clip a raster using a mask layer is not working.
Instead I received the following message:
ERROR 1: Cutline polygon is invalid.
Note that the same task (Clip a raster using a mask layer) in QGIS 2.18.23 (using the same input layers) runs without any kind of troubles.
Ramon, have you any additional suggestions???
many thanks for your attention,
Nuno
-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-
Nuno de Santos Loureiro (PhD)
Faculdade de Ciências e Tecnologia - DCTMA - Ed. 8
Universidade do Algarve
Campus de Gambelas
8005-139 FARO   (Portugal)
Sent: 22 May 2019 00:43
To: Nuno Manuel de Figueiredo de Santos Loureiro
Cc: qgis-user
Subject: Re: [Qgis-user] QGIS 6.3 for macOS 10.14.5 : HELP
Hi Nuno,
You need to set some environmental variables, so that the GDAL binaries can be found.
William provides a nice step by step in file Read Me.txt
If you’ve already deleted the dmg I’ll paste it into a reply, but you should read Read Me.txt because it contains other useful bits of information besides the answer to your question.
Regards,
Ramon.
On 22 May 2019, at 07:14, Nuno Manuel de Figueiredo de Santos Loureiro <nlourei at ualg.pt<mailto:nlourei at ualg.pt>> wrote:
Hi all,
I'm a very regular (happy) user of QGIS 2.18.23.
Recently I installed QGIS 6.3.2 on my Mac with macOS 10.14.5.
Several tasks are running very well but when I tried to merge a few rasters I was not able to do that and I received the following message:
GDAL command output:
/bin/sh: gdal_merge.py: command not found
Also, when I tried to clip a raster using a mask layer I was not able to do that and I received the following message:
/bin/sh: gdalwarp: command not found
What is missing or wrong?
Can somebody help me with some tips to fix this issue?
Many thanks in advance,
Nuno
Campus de Gambelas
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190522/0757df06/attachment-0001.html>
