[Qgis-user] QGIS 6.3 for macOS 10.14.5 : HELP
Ramon Andinach
custard at westnet.com.au
Tue May 21 18:30:09 PDT 2019
Hi Nuno,
Glad it’s mostly working.
QGIS (and its tools) slowly gets better at noticing invalid layers, and there are a lot of changes between these two versions. I’d run one of the geometry checkers over your layer, eg. Vector -> Geometry Tools -> Check Validity, and see if that shows up anything.
If that doesn’t show anything I'm probably out, but maybe one of the others could help as this isn’t a Mac specific error.
Regards,
Ramon.
> On 22 May 2019, at 09:07, Nuno Manuel de Figueiredo de Santos Loureiro <nlourei at ualg.pt> wrote:
> Hi Ramon,
> Many thanks.
> I followed your recommendations.
> However a few issues remain.
> William wrotes:
> /Library/Frameworks/Python.framework/Versions/3.6/bin:/Library/Frameworks/GDAL.framework/Versions/2.3/Programs:
> in the step by step
> But he also says that GDAL is 2.4 and not 2.3.
> I checked in my computar and I have GDAL 1.11, 2.1, GDAL 2.2 and GDAL 2.4.
> I believe that GDAL 1.11 and 2.1 is needed for QGIS 2.18.23, that GDAL 2.2 is not needed and that GDAL 2.4 is needed for QGIS 3.6.2.
> Is this true?
> After, I changed the above line to
> /Library/Frameworks/Python.framework/Versions/3.6/bin:/Library/Frameworks/GDAL.framework/Versions/2.4/Programs:
> (only 2.3 to 2.4)
> Finally the Merge a few rasters works well ;-)
> But the following step, the Clip a raster using a mask layer is not working.
> Instead I received the following message:
> ERROR 1: Cutline polygon is invalid.
> Note that the same task (Clip a raster using a mask layer) in QGIS 2.18.23 (using the same input layers) runs without any kind of troubles.
> Ramon, have you any additional suggestions???
> many thanks for your attention,
> Nuno
> -x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-
> Nuno de Santos Loureiro (PhD)
> Faculdade de Ciências e Tecnologia - DCTMA - Ed. 8
> Universidade do Algarve
> Campus de Gambelas
> 8005-139 FARO (Portugal)
> From: Ramon Andinach <custard at westnet.com.au>
> Sent: 22 May 2019 00:43
> To: Nuno Manuel de Figueiredo de Santos Loureiro
> Cc: qgis-user
> Subject: Re: [Qgis-user] QGIS 6.3 for macOS 10.14.5 : HELP
> Hi Nuno,
> You need to set some environmental variables, so that the GDAL binaries can be found.
> William provides a nice step by step in file Read Me.txt
> If you’ve already deleted the dmg I’ll paste it into a reply, but you should read Read Me.txt because it contains other useful bits of information besides the answer to your question.
> Regards,
> Ramon.
>> On 22 May 2019, at 07:14, Nuno Manuel de Figueiredo de Santos Loureiro <nlourei at ualg.pt <mailto:nlourei at ualg.pt>> wrote:
>> Hi all,
>> I'm a very regular (happy) user of QGIS 2.18.23.
>> Recently I installed QGIS 6.3.2 on my Mac with macOS 10.14.5.
>> Several tasks are running very well but when I tried to merge a few rasters I was not able to do that and I received the following message:
>> GDAL command output:
>> /bin/sh: gdal_merge.py: command not found
>> Also, when I tried to clip a raster using a mask layer I was not able to do that and I received the following message:
>> /bin/sh: gdalwarp: command not found
>> What is missing or wrong?
>> Can somebody help me with some tips to fix this issue?
>> Many thanks in advance,
>> Nuno
>> Campus de Gambelas
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190522/0be52ecd/attachment.html>
