[Qgis-user] Selecting by Oracle ROWID in version 3.4.7
Paul Wittle
paul.wittle at dorsetcouncil.gov.uk
Mon Nov 4 05:17:36 PST 2019
I have an issue with QGIS 3.4.7 as we are doing a normal select from an Oracle table (which is partitioned). We are drawing a rectangle but QGIS is selecting points outside the rectangle.
On closer inspection we found that the SQL issues searches for the ROWID rather than the value of the Primary Key (which I have tried to set when defining the layer). We think it is possible that the ROWID values on the map may not be the same as the ROWIDs returned by the queries and that is why it is selecting the wrong features.
Is this a bug which has been fixed, something I can set to manually to avoid or has anyone else noticed a similar issue?
Any hints would be great.
Cheers,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191104/660b4ba2/attachment.html>
