[Qgis-user] upgraded 3.10 project, now it no longer zooms to point location, but works on new projects
Jason Carlson
jason at starlandcounty.com
Mon Nov 4 08:43:52 PST 2019
Hi all, I've been using QGIS for just over a year now and exclusively since
about February as I didn't reinstall ArcGIS on my new computer at that time.
In QGIS 3.10 if I open a project (created in a different previous version
of QGIS ranging from 3.4 - 3.8) and then I:
1. Open an attribute table of a layer that contains point geometry
2. Select one of the records in that attribute table
3. Click "Zoom Map to selected rows"
It puts me hundreds of miles off my map entirely (so a blank screen). This
only happens with records that have single point geom (if it is a line or
polygon it works fine).
If I remove the layer and re-add it back, the problem still exists.
However, if I create a brand new project in 3.10 and add that exact same
layer (all are stored in PostGIS database), the issue is not there and it
works as expected. So the issue seems to stem from old "working" projects
that are now opened in the newer version of QGIS.
Has anyone else seen this or something similar? Is there anyway of fixing
the project file without having to recreate it all from scratch so I can
use these in the new version of QGIS?
*Jason Carlson*
IT/GIS Administrator
*403.772.3793*
*Starland County*
*Morrin, AB *
*(403) 772-3793*
**www.starlandcounty.com
<http://www.starlandcounty.com>**
*Our organization accepts no
liability for the content of this email, or for the consequences of any
actions taken on the basis of the information provided, unless that
information is subsequently confirmed in writing. The content of this
message is confidential. If you have received it by mistake, please inform
us by an email reply and then delete the message. It is forbidden to copy,
forward, or in any way reveal the contents of this message to anyone. *
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191104/91f30871/attachment.html>
