[Qgis-user] MS/SQL layer in 2D suddenly becomes 3D in QGIS preventing updates ?
Régis Haubourg
regis.haubourg at gmail.com
Thu Nov 7 02:46:58 PST 2019
Hi Lars,
from what I eard, part of this should be solved in 3.10.1 to be released
the 2019-11-22 . if you can install the qgis-release-dev build with osgeo4W
advanced installer, can you check it is OK with it?
You should also check the default Z value option in Settings/Digitizing
section. This is where you can force the default value.
Regards
Régis
Le jeu. 7 nov. 2019 à 10:14, Lars I. Nielsen, LIFA A/S <lin at lifa.dk> a
écrit :
> Hi list.
> I’m stuck in an odd situation.
> I just opened a polygon table from my MS/SQL (2016) for editing. It loads
> without problems.
> I then did some node editing, only moving existing nodes. This was saved
> without problems.
> I then tried to add a couple of new nodes, and then QGIS failed in
> committing the change !?!
> I investigated the error, and it seems that (1) QGIS adds a random Z value
> (17) to my polygon nodes, and (2) inserts a Z value of “nan” on new nodes.
> Why???
> Question 1: How do I force QGIS to not adding a dummy Z to my loaded
> polygon layer, i.e. work with it as a 2D geometry ?
> alternatively:
> Question 2: How do I force QGIS to insert a valid value e.g. a “0” for
> dummy Z values in all new nodes ?
> Yes, I have created tables (or actually views) named “geometry_column” in
> the relevant schemas _*and*_ dbo, with a value of 2 for
> “coord_dimension”. QGIS seems to disregard this setting.
> The updated polygon in MS/SQL (from the first editing) is 2D, as expected.
> Med venlig hilsen
> GIS-kons., FME+Python Certified Professional
> Geoinformatik
> [image: Beskrivelse:
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\284x82-3741133837051347070]
> *T*
> 6313 6800
> lin at lifa.dk
> *D*
> 6313 6849
> *W*
> www.lifa.dk
> *M*
> *CVR*
> 20937289
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-3019966288736195652]
> <https://www.linkedin.com/company/lifa-a-s/>
> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191107/188cab44/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191107/188cab44/attachment-0001.gif>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191107/188cab44/attachment-0001.png>
