[Qgis-user] Composer projection
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Nov 8 12:16:40 PST 2019
Yup,
My thoughts exactly! Quickmap plugin work works better than most. Be careful with the data, most have strict licenses that prohibit most use and publication.
Nicolas
> Le 8 nov. 2019 à 14:19, Alexandre Neto <senhor.neto at gmail.com> a écrit :
> Are you using basemaps like google or bing?
> If that's the case, it's the basemaps that are moving, not your dots.
> The reason is that most of those webservices are not suited for printing.
> Best regards,
> Alexandre neto
> A sexta, 8/11/2019, 14:16, MIKE MCGRADY <mikemcgrady at hotmail.com> escreveu:
>> I am a QGIS neophyte. Why when I export a map from composer are the mapped features (dots in this case) in the resulting jpg or pdf not in the same location as in composer? For example. One of my locations was in the middle of London in composer, but when saved as a jpg or pdf that location was to the NW near Oxford.
>> M. J. McGrady
>> Am Rosenhugel 59
>> A-3500 Krems
>> Austria
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191108/9beeb61d/attachment.html>
