[Qgis-user] export to dxf problem
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Nov 11 11:20:11 PST 2019
Try zooming on the data. It is quite possible that the data it there
but that the file opens very far away from the data. That is a common
problem with CADs.
Nicolas
On 2019-11-11 8:29 a.m., Boaz Bar Ilan wrote:
> thanks
> I did what you adviced
> succeeded reopen it in qgis
> but failed in the dxf viewer
> boaz
> בתאריך יום ב׳, 11 בנוב׳ 2019 ב-15:18 מאת Nicolas Cadieux
> <nicolas.cadieux at archeotec.ca <mailto:nicolas.cadieux at archeotec.ca>>:
> Hi,
> You can only save a layer file to dxf, not a project file. Try
> selecting a layer file and saving that. Then reopen in QGIS
> before testing in other software. Share the layer file and the
> exact steps followed if that does not work.
> Nicolas
>> Le 11 nov. 2019 à 08:07, Boaz Bar Ilan <boazprosie at gmail.com
>> <mailto:boazprosie at gmail.com>> a écrit :
>> hallo
>> im trying to export a project to a dxf
>> as much as I try the file appear empty and nor I and nor other
>> can open it
>> I tried all the options
>> where can I change something so that it will work ?
>> thanks
>> boaz
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191111/3cc17d94/attachment.html>
