[Qgis-user] export to dxf problem
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Nov 11 12:35:41 PST 2019
AutoCAD programs have a tendency to open the file either zoomed out or zoomed away from our zone of interest. Ex. Your lines are in Canada but the files open in France. You need to find your data. Zoom in, zoom out or pan until you find it. Sometimes, you have a function saying « zoom to layer extent ». If that does not work, try to find your data looking at coordinates system.
Don’t forget to do a « reply all » so that the user groupe can profit from the conversation.
Hope this helps
Nicolas
> Le 11 nov. 2019 à 15:15, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> What you mean zooning on the data ?
> בתאריך יום ב׳, 11 בנוב׳ 2019, 21:20, מאת Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
>> Hi,
>> Try zooming on the data. It is quite possible that the data it there but that the file opens very far away from the data. That is a common problem with CADs.
>> Nicolas
>> On 2019-11-11 8:29 a.m., Boaz Bar Ilan wrote:
>>> thanks
>>> I did what you adviced
>>> succeeded reopen it in qgis
>>> but failed in the dxf viewer
>>> boaz
>>> בתאריך יום ב׳, 11 בנוב׳ 2019 ב-15:18 מאת Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
>>>> Hi,
>>>> You can only save a layer file to dxf, not a project file. Try selecting a layer file and saving that. Then reopen in QGIS before testing in other software. Share the layer file and the exact steps followed if that does not work.
>>>> Nicolas
>>>>> Le 11 nov. 2019 à 08:07, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
>>>>> hallo
>>>>> im trying to export a project to a dxf
>>>>> as much as I try the file appear empty and nor I and nor other can open it
>>>>> I tried all the options
>>>>> where can I change something so that it will work ?
>>>>> thanks
>>>>> boaz
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191111/224c7541/attachment.html>
