[Qgis-user] Can't find the the Print Composer window while creating a basic map layout in QGIS 3.4 Madeira
Phil Wyatt
phil at wyatt-family.com
Tue Nov 12 19:39:36 PST 2019
Hi Donald,
Try Project, Layout Manager and then create a new layout. That’s should get you started. Also to change the page size…Right click on the page, Page Properties and set up a custom page with the dimensions required
Cheers - Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Donald Meier
Sent: Wednesday, 13 November 2019 2:25 PM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Can't find the the Print Composer window while creating a basic map layout in QGIS 3.4 Madeira
I am trying to lay out a map to export and print at a larger size, approximately 24 x 36 inches or A1. The help tutorial for the version says to followthhis path: Projects -> Layouts -> Composer Manager -> Print Composer. In my version there is no Composer Manager or Print Composer in any menu I can find. Can anyone help with this?
Thanks in advance!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191113/63d9cfb7/attachment.html>
