[Qgis-user] Experiences using QGIS + PostgreSQL/PostGIS in a multiuser environment?
Andreas Neumann
a.neumann at carto.net
Wed Nov 20 02:40:08 PST 2019
Are those 15 people in the same office/same location or distributed? If
the latter, at how many places are they distributed?
In my experience, using Postgis sources over the internet (not in the
LAN) is way too slow. It will only upset your users. In such a scenario
you would have to set up replication.
Another aspect: avoid editing the same features simultaneously by
different users. Only the last save will stay. QGIS starts an edit
session and will only save at the end of the sesssion, when you actually
save the features. In such a scenario you should assign certain
geographic areas to different users (e.g. user A edits features in
municipality x, and user b in municipality y, but not x).
Otherwise you will have to deal with handling conflicts. That would
require more complicated table setups with versioning and conflict
detection.
Andreas
On 2019-11-20 11:32, HernĂ¡n De Angelis wrote:
> I am evaluating setting up a server running PostgreSQL/PostGIS for use as data sharing/collaborating environment for spatial data. The user
> group may consist of up to 15 people, mostly using QGIS but one or two
> may use other software (non OS). Data is almost exclusively of vector
> type. The use is within a single organization.
> I understand some people in this list have experience with this kind of
> environment and would appreciate if any of you would share any useful
> experience, challenges, thought or things to watch out for. I understand
> basic management routines are critical (user management, user rights),
> as well as a sound backup and update strategy. I also understand that
> proper data management procedures have to be in place, like rules for
> table creation and eventual deletion, attribute selection, etc. But what
> else can go wrong with this kind of setup if not managed properly?
> Thoughts and experiences welcome! in our experience the solution is pretty straightforward. The only other
> challenge I'd add is having good bandwidth, otherwise using PostGIS data
> can be sluggish.
> All the best.
Excellent point, Paolo! I had not thought about it. Thank you!
All the best
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191120/8bbfc26e/attachment.html>
