[Qgis-user] Experiences using QGIS + PostgreSQL/PostGIS in a multiuser environment?
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed Nov 20 03:13:06 PST 2019
Some other things to consider:
- Indexing (especially spatial indexing) your vectors.
- Meta-data: trying to capture meta-data as you go. There are some plugins
available (Layer Metadata Search: which both captures and allows you to
search for your meta-data...happy to help with the set up if you need
assistance).
Hope that helps.
Regards
Saber
On Wed, 20 Nov 2019 at 11:08, Hernán De Angelis <dhdeangelis at comhem.se>
wrote:
> Hello Andreas
> Thank you very much for your comment. These are definitely things I did
> not think about.
> Our people are in two separate buildings (in two separate regions!) but
> our systems can handle this without problems.
> The editing conflicts seem more serious to me. I guess these could be
> minimized by encouraging users to save edits more often but, as you write,
> a proper solution may require proper versioning. But then that may likely
> push up the costs.
> Good material for thought and a test.
> Thank you again!
> Hernán
> On 2019-11-20 11:40, Andreas Neumann wrote:
> Are those 15 people in the same office/same location or distributed? If
> the latter, at how many places are they distributed?
> In my experience, using Postgis sources over the internet (not in the LAN)
> is way too slow. It will only upset your users. In such a scenario you
> would have to set up replication.
> Another aspect: avoid editing the same features simultaneously by
> different users. Only the last save will stay. QGIS starts an edit session
> and will only save at the end of the sesssion, when you actually save the
> features. In such a scenario you should assign certain geographic areas to
> different users (e.g. user A edits features in municipality x, and user b
> in municipality y, but not x).
> Otherwise you will have to deal with handling conflicts. That would
> require more complicated table setups with versioning and conflict
> detection.
> Andreas
> On 2019-11-20 11:32, Hernán De Angelis wrote:
> I am evaluating setting up a server running PostgreSQL/PostGIS for use
> as data sharing/collaborating environment for spatial data. The user
> group may consist of up to 15 people, mostly using QGIS but one or two
> may use other software (non OS). Data is almost exclusively of vector
> type. The use is within a single organization.
> I understand some people in this list have experience with this kind of
> environment and would appreciate if any of you would share any useful
> experience, challenges, thought or things to watch out for. I understand
> basic management routines are critical (user management, user rights),
> as well as a sound backup and update strategy. I also understand that
> proper data management procedures have to be in place, like rules for
> table creation and eventual deletion, attribute selection, etc. But what
> else can go wrong with this kind of setup if not managed properly?
> Thoughts and experiences welcome!
> in our experience the solution is pretty straightforward. The only other
> challenge I'd add is having good bandwidth, otherwise using PostGIS data
> can be sluggish.
> All the best.
> Excellent point, Paolo! I had not thought about it. Thank you!
> All the best
> Qgis-user mailing list
Saber Razmjooei
www.lutraconsulting.co.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191120/4551c816/attachment.html>
