[Qgis-user] Experiences using QGIS + PostgreSQL/PostGIS in a multiuser environment?
Hernán De Angelis dhdeangelis at comhem.se
Wed Nov 20 03:14:00 PST 2019
Yes, Paolo. I understand. A lot of problems can be avoided by proper
design and implementation of the workflow.
Thanks you and all for your valuable input!
Best
Hernán
On 2019-11-20 12:12, Paolo Cavallini wrote:
> IMHO conflicts should never arise if the workflow is properly designed:
> two users should never edit the same feature at the same time.
> you can solve a lot of these issues with table partitioning.
> cheers
> Il 20/11/19 12:08, Hernán De Angelis ha scritto:
>> Hello Andreas
>> Thank you very much for your comment. These are definitely things I did
>> not think about.
>> Our people are in two separate buildings (in two separate regions!) but
>> our systems can handle this without problems.
>> The editing conflicts seem more serious to me. I guess these could be
>> minimized by encouraging users to save edits more often but, as you
>> write, a proper solution may require proper versioning. But then that
>> may likely push up the costs.
>> Good material for thought and a test.
>> Thank you again!
>> Hernán
>> On 2019-11-20 11:40, Andreas Neumann wrote:
>>> Are those 15 people in the same office/same location or distributed?
>>> If the latter, at how many places are they distributed?
>>> In my experience, using Postgis sources over the internet (not in the
>>> LAN) is way too slow. It will only upset your users. In such a
>>> scenario you would have to set up replication.
>>> Another aspect: avoid editing the same features simultaneously by
>>> different users. Only the last save will stay. QGIS starts an edit
>>> session and will only save at the end of the sesssion, when you
>>> actually save the features. In such a scenario you should assign
>>> certain geographic areas to different users (e.g. user A edits
>>> features in municipality x, and user b in municipality y, but not x).
>>> Otherwise you will have to deal with handling conflicts. That would
>>> require more complicated table setups with versioning and conflict
>>> detection.
>>> Andreas
>>> On 2019-11-20 11:32, Hernán De Angelis wrote:
>>>> I am evaluating setting up a server running PostgreSQL/PostGIS for use
>>>>>> as data sharing/collaborating environment for spatial data. The user
>>>>>> group may consist of up to 15 people, mostly using QGIS but one or two
>>>>>> may use other software (non OS). Data is almost exclusively of vector
>>>>>> type. The use is within a single organization.
>>>>>> I understand some people in this list have experience with this kind of
>>>>>> environment and would appreciate if any of you would share any useful
>>>>>> experience, challenges, thought or things to watch out for. I understand
>>>>>> basic management routines are critical (user management, user rights),
>>>>>> as well as a sound backup and update strategy. I also understand that
>>>>>> proper data management procedures have to be in place, like rules for
>>>>>> table creation and eventual deletion, attribute selection, etc. But what
>>>>>> else can go wrong with this kind of setup if not managed properly?
>>>>>> Thoughts and experiences welcome!
>>>>> in our experience the solution is pretty straightforward. The only other
>>>>> challenge I'd add is having good bandwidth, otherwise using PostGIS data
>>>>> can be sluggish.
>>>>> All the best.
>>>> Excellent point, Paolo! I had not thought about it. Thank you!
>>>> All the best
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
