[Qgis-user] Experiences using QGIS + PostgreSQL/PostGIS in a multiuser environment?
Paolo Cavallini
cavallini at faunalia.it
Wed Nov 20 03:12:00 PST 2019
IMHO conflicts should never arise if the workflow is properly designed:
two users should never edit the same feature at the same time.
you can solve a lot of these issues with table partitioning.
cheers
Il 20/11/19 12:08, Hernán De Angelis ha scritto:
> Hello Andreas
> Thank you very much for your comment. These are definitely things I did
> not think about.
> Our people are in two separate buildings (in two separate regions!) but
> our systems can handle this without problems.
> The editing conflicts seem more serious to me. I guess these could be
> minimized by encouraging users to save edits more often but, as you
> write, a proper solution may require proper versioning. But then that
> may likely push up the costs.
> Good material for thought and a test.
> Thank you again!
> Hernán
> On 2019-11-20 11:40, Andreas Neumann wrote:
>> Are those 15 people in the same office/same location or distributed?
>> If the latter, at how many places are they distributed?
>> In my experience, using Postgis sources over the internet (not in the
>> LAN) is way too slow. It will only upset your users. In such a
>> scenario you would have to set up replication.
>> Another aspect: avoid editing the same features simultaneously by
>> different users. Only the last save will stay. QGIS starts an edit
>> session and will only save at the end of the sesssion, when you
>> actually save the features. In such a scenario you should assign
>> certain geographic areas to different users (e.g. user A edits
>> features in municipality x, and user b in municipality y, but not x).
>> Otherwise you will have to deal with handling conflicts. That would
>> require more complicated table setups with versioning and conflict
>> detection.
>> Andreas
>> On 2019-11-20 11:32, Hernán De Angelis wrote:
>>> I am evaluating setting up a server running PostgreSQL/PostGIS for use
>>>>> as data sharing/collaborating environment for spatial data. The user
>>>>> group may consist of up to 15 people, mostly using QGIS but one or two
>>>>> may use other software (non OS). Data is almost exclusively of vector
>>>>> type. The use is within a single organization.
>>>>> I understand some people in this list have experience with this kind of
>>>>> environment and would appreciate if any of you would share any useful
>>>>> experience, challenges, thought or things to watch out for. I understand
>>>>> basic management routines are critical (user management, user rights),
>>>>> as well as a sound backup and update strategy. I also understand that
>>>>> proper data management procedures have to be in place, like rules for
>>>>> table creation and eventual deletion, attribute selection, etc. But what
>>>>> else can go wrong with this kind of setup if not managed properly?
>>>>> Thoughts and experiences welcome!
>>>> in our experience the solution is pretty straightforward. The only other
>>>> challenge I'd add is having good bandwidth, otherwise using PostGIS data
>>>> can be sluggish.
>>>> All the best.
>>> Excellent point, Paolo! I had not thought about it. Thank you!
>>> All the best
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
