[Qgis-user] Experiences using QGIS + PostgreSQL/PostGIS in a multiuser environment?
Hernán De Angelis
dhdeangelis at comhem.se
Thu Nov 21 06:21:22 PST 2019
Bo Victor, this is an extremely good contribution to this topic. Thanks
you very much!
/H.
On 2019-11-21 11:43, Bo Victor Thomsen wrote:
> This reply is rather long and some of the information has already
> partly been given in other replies. However, the following list is my
> "checklist" for using Postgres/PostGIS with QGIS and other GIS programs.
> * Postgres is an excellent platform for creating a multi user
> spatial data platform. And - for QGIS - faster than using just
> about any other spatial storage technology. But you have prepare
> your Postgres setup.
> * Memory configuration: Out of the box Postgres is *very*
> conservative about using memory. Tune the configuration. If you
> don't have the know-how or time use a tool like this:
> *https://pgtune.leopard.in.ua/#/* (there is one aber-dabei: Choose
> "Linux" as the operating system even if you server is Windows. The
> old advise about using only 512 MB shared memory on windows is
> obsolete:
> *https://momjian.us/main/blogs/pgblog/2018.html#December_17_2018*)
> * If you have a serious multi CPU server (And who hasn't ?): Use
> Postgres 12 / PostGIS 3 for getting maximum performance using
> multiprocessing in Postgres/PostGIS:
> *http://blog.cleverelephant.ca/2019/08/postgis-3-parallel.html
> *(and tune your Postgres accordingly - see above). Yes I know
> about QGIS troubles with Postgres 12. They will hopefully be
> resolved quickly.
> * If you have a "Windows only" setup i.e both the server and the
> clients are Windows, consider using SSPI sign on method:
> *https://wiki.postgresql.org/wiki/Configuring_for_single_sign-on_using_SSPI_on_Windows*
> It's equivalent to "Integrated security" for MS-SQLServer and will
> reduce the hassle about user credentials for Postgres, because the
> server will reuse the windows logon identity inside Postgres.
> * And a little know trick: If you have a lot of large complex
> geometries and some extra disk capacity you can speed your queries
> considerably by *not* compressing TOAST data for your spatial
> tables:
> *http://blog.cleverelephant.ca/2018/09/postgis-external-storage.html.
> * (This information is probably not pertinent for you as this time)
> If you have a "large" pool of users where a small part is
> "editors" and a large part "read-only" users, consider having 2
> Postgres servers:
> o One for editing users, where the Postgres setup is tuned for
> editing. Only editing user is allowed access to this server.
> The server can probably be quite small.
> o A second Postgres server tuned for read access. All Postgres
> users has only read access to this server. This server is the
> larger of the servers.
> o Connect the 2 server in a master/slave replication
> configuration using the "editor" server as a master. This will
> remove any problems for "editor"-users when "read"-users blow
> up the read server with some convoluted query (And they will !!)
> Med venlig hilsen / Kind regards
> Bo Victor Thomsen
> Den 20-11-2019 kl. 11:10 skrev Hernán De Angelis:
>> Hello QGIS:ers
>> I am evaluating setting up a server running PostgreSQL/PostGIS for
>> use as data sharing/collaborating environment for spatial data. The
>> user group may consist of up to 15 people, mostly using QGIS but one
>> or two may use other software (non OS). Data is almost exclusively of
>> vector type. The use is within a single organization.
>> I understand some people in this list have experience with this kind
>> of environment and would appreciate if any of you would share any
>> useful experience, challenges, thought or things to watch out for. I
>> understand basic management routines are critical (user management,
>> user rights), as well as a sound backup and update strategy. I also
>> understand that proper data management procedures have to be in
>> place, like rules for table creation and eventual deletion, attribute
>> selection, etc. But what else can go wrong with this kind of setup if
>> not managed properly? Thoughts and experiences welcome!
>> Best regards and thanks in advance
>> Hernán
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191121/622848d4/attachment.html>
