[Qgis-user] Experiences using QGIS + PostgreSQL/PostGIS in a multiuser environment?
Hernán De Angelis dhdeangelis at comhem.se
Thu Nov 21 06:22:29 PST 2019
Thank you for the recommendation, Luis.
/H.
On 2019-11-20 18:24, Luis Franco Vázquez wrote:
> By mistake I didn't answered in the thread. Here are my two cents.
> You should avoid opening ports in postgresql server by using ssh
> tunneling.
> My experience is that this kind of infrastructure can be slow for
> remote connections. Take a look to the offline editing plugin or maybe
> (it's only an idea) you can have slave postgresql servers in each
> building and some kind of synchronization with the master one.
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> El miércoles, 20 de noviembre de 2019 14:15, Andreas Neumann
> <a.neumann at carto.net> escribió:
>> Hi Luigi and Alessandro,
>> thanks for the clarifications.
>> Quick other question: is it correct that the id MUST be exactly 7
>> characters Less than or more than 7 characters won't work? At least
>> on my system saving the config is deactivated if it is less than 7 chars.
>> Thanks,
>> Andreas
>> On 2019-11-20 13:46, Alessandro Pasotti wrote:
>>> On Wed, Nov 20, 2019 at 1:24 PM Andreas Neumann <a.neumann at carto.net
>>> <mailto:a.neumann at carto.net>> wrote:
>>>     Hi,
>>>     I wonder what is best practice to handle auth configs across
>>>     several users for sharing of projects?
>>>     Should we ask users to create the same auth-config ids/names to
>>>     make projects interoperable, where each users would have
>>>     different credentials, but share the auth-config id that is
>>>     stored in the QGIS project file?
>>>     Is this how we should do it? Otherwise users would end up with
>>>     different auth-ids and then can't open QGIS files from their
>>>     colleagues without a hassle ...
>>>     Or are there better/alternative approaches?
>>> One of the best ways we've used so far was to pre-define at the
>>> organization level a small set of authids, you are limited to 7
>>> chars but that's not a big issue.
>>> So, when creating project you will use one of the pre-defined auth
>>> ids, of course every user will have to use his own local QGIS auth
>>> DB (this is all handled transparently by the QGIS auth system) where
>>> he stores his own credentials.
>>> If you share your project within your organization, as long as the
>>> user who receives the project has his credentials already sets for
>>> the given auth ids access will be granted automatically, if not he
>>> will be prompted to enter credentials and if he stores them in the
>>> QGIS auth local DB this will be required only for the first time.
>>> This system gives the sysadmins full flexibility: individual
>>> credentials can be revoked/granted, no need to share any auth DB in
>>> any case.
>>> Hope this helps.
>>>     Andreas
>>>     On 2019-11-20 13:14, Hernán De Angelis wrote:
>>>         Interesting point, Luigi. Thank you!
>>>         Hernán
>>>         On 2019-11-20 12:58, Luigi Pirelli wrote:
>>>             this is not an issue, Postgres support many auth systems
>>>             most of them paired with the authentication system
>>>             implemented in QGIS. Other problem is how to share
>>>             (auth.db) credentials or security setting among
>>>             different users.
>>>             Luigi Pirelli
>>>             * LinkedIn: https://www.linkedin.com/in/luigipirelli
>>>             * Stackexchange:
>>>             http://gis.stackexchange.com/users/19667/luigi-pirelli
>>>             * GitHub: https://github.com/luipir
>>>             * Book: Mastering QGIS3 - 3rd Edition
>>>             <https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
>>>             * Hire a team: http://www.qcooperative.net
>>>             On Wed, 20 Nov 2019 at 11:53, Jan-Eric Oskarsson
>>>             <jan-eric at kregis.se <mailto:jan-eric at kregis.se>> wrote:
>>>>             Hi Hernán!
>>>>             Maybe this comment is redundant but you have to set up
>>>>             a strong security to prevent hackers to hack your
>>>>             database and steal your data and cause damage.
>>>>             I hope uthat you already have thought about this issu!
>>>>             Kind Regards
>>>>             Jan-Eric
>>>>             -----Ursprungligt meddelande-----
>>>>             Från: Qgis-user <qgis-user-bounces at lists.osgeo.org
>>>>             <mailto:qgis-user-bounces at lists.osgeo.org>> För Hernán
>>>>             De Angelis
>>>>             Skickat: den 20 november 2019 11:10
>>>>             Till: qgis-user <qgis-user at lists.osgeo.org
>>>>             <mailto:qgis-user at lists.osgeo.org>>
>>>>             Ämne: [Qgis-user] Experiences using QGIS +
>>>>             Hello QGIS:ers
>>>>             I am evaluating setting up a server running
>>>>             PostgreSQL/PostGIS for use as data
>>>>             sharing/collaborating environment for spatial data. The
>>>>             user group may consist of up to 15 people, mostly using
>>>>             QGIS but one or two may use other software (non OS).
>>>>             Data is almost exclusively of vector type. The use is
>>>>             within a single organization.
>>>>             I understand some people in this list have experience
>>>>             with this kind of environment and would appreciate if
>>>>             any of you would share any useful experience,
>>>>             challenges, thought or things to watch out for. I
>>>>             understand basic management routines are critical (user
>>>>             management, user rights), as well as a sound backup and
>>>>             update strategy. I also understand that proper data
>>>>             management procedures have to be in place, like rules
>>>>             for table creation and eventual deletion, attribute
>>>>             selection, etc. But what else can go wrong with this
>>>>             kind of setup if not managed properly?
>>>>             Thoughts and experiences welcome!
>>>>             Best regards and thanks in advance
>>>>             Hernán
>>>>             _______________________________________________
>>>>             Qgis-user mailing list
>>>>             Qgis-user at lists.osgeo.org
>>>>             <mailto:Qgis-user at lists.osgeo.org>
>>>>             List info:
>>>>             https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>             Unsubscribe:
>>>>             List info:
>>>>             Unsubscribe:
>>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Alessandro Pasotti
>>> w3: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191121/89bdf211/attachment.html>
