[Qgis-user] Automatically force reload layer from source (geojson)
Richard Duivenvoorde
rdmailings at duif.net
Fri Nov 22 05:38:33 PST 2019
Hi Olivier,
Does F5 (refresh, from menu 'View/Refresh') not work?
I thought that when I had an (live changing) online geojson source, (and
added as url), I could easily 'reload' fresh data via F5
Not working for you?
Regards,
On 22/11/2019 14.12, Olivier Dalang wrote:
> Dear list,
> Currently, when I load a geojson into QGIS, and modify the geojson file
> using an other software, the change isn't reflected in QGIS. The only
> way to reflect the change is to re-add the layer, or to run
> `iface.activeLayer().dataProvider().forceReload()` in the python console.
> I see could find neither a button or menu to trigger a reload manually,
> nor the option to do it automatically, nor a way to disable caching of
> such layers (which anyway would be suitable for very small layers only).
> Ideally, I was looking for an option like the "refresh layer at
> interval" options from the layer properties>rendering dialog (that
> option seems to just re-render theĀ file, without reloading it, so that
> it doesn't work for my purpose).
> Thanks !
> Olivier
> Qgis-user mailing list
