[Qgis-user] [QGIS-Developer] Drill-down forms with multiple selections option
Alexandre Neto
senhor.neto at gmail.com
Sat Nov 23 08:58:27 PST 2019
Hi Pedro,
Can't you check if "di" is present in the {Value1,Value2,...} set?
If needed, you can replace the curly brackets by curved ones and run the
all expression by eval()
Alexandre Neto
A sábado, 23/11/2019, 13:48, Pedro Venâncio <pedrongvenancio at gmail.com>
escreveu:
> Hi all,
> I'm building a form with two fields of "Value Relation Widgets", one
> depending on the other.
> This works really well as explained here https://youtu.be/ipezh4KXrgo by
> Alessandro, but I would like that both fields have the multiple selections
> option.
> Here is a sample project:
> https://cld.pt/dl/download/db1a1787-0adc-4633-a0c9-356c41f269eb/drilldown_multiple.zip
> In that project, I have two shapefiles (one configured without and another
> configured with 'Allow multiple selections') and two csv files (Value
> Relation sources).
> So, without multiple selections option, I simply use
> "di" = current_value( 'DISTRITOS')
> as filter expression.
> This does not work with multiple selections, because this option saves the
> multiple values between braces: {Value1,Value2,...}.
> So, how could I use the filter here, to have the second field filtered by
> the options selected in the first field?
> Thank you very much!
> Best regards,
> Pedro Venâncio
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191123/f2e00d07/attachment.html>
