[Qgis-user] QGIS 3.10 - wgs84 (epsg4326) file disappears in pseudo-mercator-project (epsg:3857)
Even Rouault
even.rouault at spatialys.com
Sun Nov 24 09:06:42 PST 2019
On dimanche 24 novembre 2019 16:40:02 CET GrĂ¼n, Michael wrote:
> Hi all,
> since QGIS 3.10 I have a problem with in wgs84 projected files. When I
> change the whole qgis-project to pseudo-mercator (epsg:3857) it was up to
> QGIS 3.8. no problem to draw the wgs84-projected files correctly within
> epsg:3857-projects. Now in QGIS3.10. the wgs84-projected files
> disappear...the layer is turned on, but the data are not visible....they
> only get drawn when I change the whole project to wgs84 (epsg:4326), which
> is not comfortable for cartographic reasons... The settings options for crs
> in 3.10 are the same as in 3.8...what changed there? Thanx for any
> hints....best regards, Michael
Michael,
It sounds pretty much like https://github.com/qgis/QGIS/issues/32973 that has
been fixed 2 days ago in master, and has been backported to the 3.10 branch as
well for the next point release.
You might try the latest nightly build of qgis-dev of OSGeo4W to see if that
fixes things.
Even
http://www.spatialys.com
