[Qgis-user] [QGIS-Developer] Python Implementation of QgsNetworkContentFetcher
Nyall Dawson
nyall.dawson at gmail.com
Wed Nov 27 14:29:47 PST 2019
On Thu, 28 Nov 2019 at 02:07, C Hamilton <adenaculture at gmail.com> wrote:
> For some reason I cannot seem to get QgsBlockingNetworkRequest to work. Also I think there is an error in the documentation where it says, "After completion of a request, the reply content should be retrieved by calling getReplyContent()." It appears to me to be reply().
> This is basically my code. Am I doing something wrong?
> request = QgsBlockingNetworkRequest()
> request.setAuthCfg(authcfg)
> error_code = request.get(QNetworkRequest(QUrl(url)), forceRefresh=True)
> The error that is returned is a ServerExceptionError. Is QgsBlockingNetworkRequest really handling redirects?
Got a public test case and I experiment with?
Nyall
> I've had luck with QgsFileDownloader, but using a method you say I shouldn't. This works.
> tempfile = QgsProcessingUtils.generateTempFilename('data.json')
> loop = QEventLoop()
> dl = QgsFileDownloader(QUrl(url), tempfile, authcfg, delayStart=True)
> dl.downloadExited.connect(loop.quit)
> dl.startDownload()
> loop.exec_()
> In this case the data was correctly written into the tempfile.
> On Wed, Nov 27, 2019 at 12:35 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> On Wed, 27 Nov 2019 at 15:26, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>> > Thanks Nyall for the precisions.
>> > I wasn't aware of QgsBlockingNetworkRequest.
>> > So basically, if I don't require authcf, then starting from 3.6 there is no reason to use my python nam, I should use both QgsNetworkContentFetcher and QgsBlockingNetworkRequest. And from 3.10 if require authcfg in QgsNetworkContentFetcher.
>> > Is this correct?
>> QgsBlockingNetworkRequest has always supported auth, so you should use
>> that in 3.6 and above in all situations WHEN you need a blocking
>> request.
>> QgsNetworkContentFetcher is async, so definitely prefer to use that
>> whenever you don't need a blocking request.
>> I'd say the matrix is something like
>> QGIS 3.4:
>> Blocking:
>> With auth: python nam (but be aware that it CAN and DOES crash
>> crashes if used on the main thread)
>> Without auth: python nam (but be aware that it CAN and DOES crash
>> Non-blocking:
>> With auth: nothing available off-the-shelf -- roll your own
>> using raw the qt and QGIS auth api?
>> Without auth: QgsNetworkContentFetcher
>> QGIS 3.6 - 3.8:
>> Blocking:
>> With auth: QgsBlockingNetworkRequest
>> Without auth: QgsBlockingNetworkRequest
>> Non-blocking:
>> QGIS 3.10:
>> Blocking:
>> Non-blocking:
>> With auth: QgsNetworkContentFetcher
>> Nyall
>> > Cheers,
>> > Denis
>> > Le mer. 27 nov. 2019 à 00:27, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
>> >> On Wed, 27 Nov 2019 at 00:44, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>> >> > Hi,
>> >> > Jumping late but we use the work from NAM Alessandro did in a couple of locator filters.
>> >> > https://github.com/opengisch/qgis-swiss-locator/blob/master/swiss_locator/core/network_access_manager.py
>> >> > I believe I have done very very few adaptations/fixes to the original work and it works like a charm.
>> >> Not quite. It works in some circumstances, but it uses an event loop.
>> >> So if you run it on the main thread, you're potentially doing an
>> >> effective call to QApplication.processEvents, which can lead to all
>> >> sorts of crashes. That said, it's generally a safe approach to use for
>> >> QGIS <= 3.4... just don't use it in any code which relates to
>> >> rendering!
>> >> > I had in mind to bring this as is within QGIS core for some time. The main point being for us the blocking request rather than authcfg.
>> >> That's EXACTLY what QgsBlockingNetworkRequest is -- please don't
>> >> re-re-implement this!
>> >> Nyall
>> >> > Denis
>> >> > Le mar. 26 nov. 2019 à 15:36, C Hamilton <adenaculture at gmail.com> a écrit :
>> >> >> Thanks everyone. This gives me some good ideas. These are the possible solutions:
>> >> >> 1. Write a python implementation of QgsNetworkContentFetcher or QgsBlockingNetworkRequest. With this I could look at the QGIS version and if it is 3.10 or greater import the core method; otherwise, import the python implementation.
>> >> >> 2. Use the old Boundless implementation if it still works in QGIS 3.
>> >> >> 3. Use QgsFileDownloader and save it as a temporary file before processing.
>> >> >> Calvin
>> >> >> On Tue, Nov 26, 2019 at 2:29 AM Alessandro Pasotti <apasotti at gmail.com> wrote:
>> >> >>> On Tue, Nov 26, 2019 at 8:22 AM Richard Duivenvoorde <rdmailings at duif.net> wrote:
>> >> >>>> On 26/11/2019 00.06, Nyall Dawson wrote:
>> >> >>>> > There's not. But there's the ex-boundless "networkaccessmanager"
>> >> >>>> > implementation that supports authcfg, which you can find at
>> >> >>>> > https://github.com/north-road/qgis-redistricting-plugin/blob/master/redistrict/linz/networkaccessmanager.py
>> >> >>>> > (and other projects -- as far as I'm aware there's no real upstream
>> >> >>>> > for this... Alessandro?).
>> >> >>>> I used this Boundless thingie for several plugins now (original source
>> >> >>>> is now pointing/redirecting to planetlabs [0]).
>> >> >>> Yes, that's the "upstream" but I don't know if that one is maintained anymore.
>> >> >>> Btw, there is also a specialized class for sync/async downloads that supports authcfg: https://qgis.org/api/classQgsFileDownloader.html#details
>> >> >>>> I think we already discussed several times that it would be good to
>> >> >>>> incorporate this into a commons lib for QGIS. But if I'm correct the
>> >> >>>> actual interface was not exactly what some wanted, and if I recall
>> >> >>>> correct Nyall tried to pull this into c++ but hit some multithreading
>> >> >>>> issues.
>> >> >>>> But as Nyall says: I think this is a great lib to use in a plugin (also
>> >> >>>> because it used the QgisNetwork-stuff, so you can receive the signals
>> >> >>>> from it or log the precise urls, like we do in the QGISnetworklogger
>> >> >>>> plugin [1]
>> >> >>>> Regards,
>> >> >>>> [0]
>> >> >>>> https://github.com/planetfederal/lib-qgis-commons/blob/master/qgiscommons2/network/networkaccessmanager.py
>> >> >>>> [1] https://github.com/rduivenvoorde/qgisnetworklogger
>> >> >>>> _______________________________________________
>> >> >>>> Qgis-user mailing list
>> >> >>>> Qgis-user at lists.osgeo.org
>> >> >>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> >>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> >>> Alessandro Pasotti
>> >> >>> w3: www.itopen.it
>> >> >> QGIS-Developer mailing list
>> >> >> QGIS-Developer at lists.osgeo.org
>> >> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
