[Qgis-user] Problems with setting network timeouts in QGIS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Nov 28 10:13:14 PST 2019
Hi Lars,
I haven't seen your initial posts, but did you confirm that the WFS
GetFeature request actually runs when you do it manually, through your
browser?
A lot of times the timeout happens at the server end (and not at the
client/QGIS end). Here is a test with the MapServer engine (not sure
what is driving your own WFS instance) :
For example, this will take a few minutes but will return all features
in your browser:
https://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=continents
That confirms there is no timeout issue on the server end.
So then I started QGIS (an old 3.8 on this machine), zoomed out to world
extents and then added the 'continents' layers from that WFS service:
It took my local QGIS several minutes, or more, there was a nice
progress bar, but eventually all features loaded. (I have not modified
the ini file that you mentioned)
I am not sure where you see this 60second limit in QGIS.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-11-28 10:59 AM, Lars I. Nielsen, LIFA A/S wrote:
> Hi list.
> I’m revisiting our problems with long WFS transactions that time out
> locally in QGIS even though the transaction continues in the background.
> The default timeout value is 60 seconds (60k msecs).
> There are two places where it can be changed in QGIS settings, but
> neither respects any changes made. Or must something else be done to
> save the value besides pressing OK ?
> I hacked the INI file to set my value to 1.2m seconds (20 minutes), but
> it seems that QGIS doesn’t respect that value, and times out my WFS
> transaction after circa 100 seconds. But it does display the large value
> in settings.
> Can anyone confirm this behavior ?
> Still running 3.4.9
> Med venlig hilsen
> GIS-kons., FME+Python Certified Professional
> Geoinformatik
> Beskrivelse:
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\284x82-3741133837051347070
