[Qgis-user] QGIS Server - Click Tolerance for GetFeatureInfo Requests
Charlotte Toma (WhereGroup)
charlotte.toma at wheregroup.com
Fri Oct 25 01:00:08 PDT 2019
Hello Alessandro,
thanks - this is exactly what i was looking for!
Can you define the FI_POINT_TOLERANCE, FI_LINE_TOLERANCE or
FI_POLYGON_TOLERANCE in the project settings or your qgs-file?
As far as I understand the documentation you can only add this parameter
when you make an GetFeatureInfo requests, but I would like to add this
parameter as a default value (like version/layers/e.g).
Another question: Is it possible to use the MAPTIP instead of the normal
attribute fields (e.g. ONLY_MAPTIP=true)? If you activate the function
(WITH_MAPTIP=true), then it is at the end of the table as a new column -
but i want it without the rest of the attribute columns for my wms.
Greetings,
Charly
Am 25.10.19 um 09:46 schrieb Alessandro Pasotti:
> On Fri, Oct 25, 2019 at 9:41 AM Charlotte Toma (WhereGroup)
> <charlotte.toma at wheregroup.com <mailto:charlotte.toma at wheregroup.com>>
> wrote:
> Hello everybody,
> I would like to know if you can increase the click tolerance for the
> GetFeatureInfo query from QGIS Server.
> I created some WMS and would like to change the sensitivity for point
> based queries. I only know how to do that with Mapserver
> (TOLERANCE)...
> I am looking forward to your feedback and thanks!
> Charly
> Hi Charly,
> isn't the answer to your question in the documentation?
> https://docs.qgis.org/3.4/en/docs/user_manual/working_with_ogc/server/services.html#getfeatureinfo
> If you had any problem finding the documentation then please let us know.
> Where2B Konferenz 2019
> 12. Dezember 2019 in Bonn
> where2b-conference.com <http://where2b-conference.com>
> Charlotte Toma
> GIS-Consultant
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 24
> Fax: +49 (0)228 / 90 90 38 - 11
> info at wheregroup.com <mailto:info at wheregroup.com>
> www.wheregroup.com <http://www.wheregroup.com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
Charlotte Toma
GIS-Consultant
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191025/e5eb4446/attachment.html>
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191025/e5eb4446/attachment.key>
