[Qgis-user] QGIS Server - Click Tolerance for GetFeatureInfo	Requests
    Alessandro Pasotti
    apasotti at gmail.com
    Sat Oct 26 04:22:06 PDT 2019
On Fri, Oct 25, 2019, 10:00 Charlotte Toma (WhereGroup) <
charlotte.toma at wheregroup.com> wrote:
> Hello Alessandro,
> thanks - this is exactly what i was looking for!
> Can you define the FI_POINT_TOLERANCE, FI_LINE_TOLERANCE or
> FI_POLYGON_TOLERANCE in the project settings or your qgs-file?
> As far as I understand the documentation you can only add this parameter
> when you make an GetFeatureInfo requests, but I would like to add this
> parameter as a default value (like version/layers/e.g).
That's not currently possible.
Another question: Is it possible to use the MAPTIP instead of the normal
> attribute fields (e.g. ONLY_MAPTIP=true)? If you activate the function
> (WITH_MAPTIP=true), then it is at the end of the table as a new column -
> but i want it without the rest of the attribute columns for my wms.
Sorry, I am not sure if I understand this question.
Greetings,
> Charly
> Am 25.10.19 um 09:46 schrieb Alessandro Pasotti:
> On Fri, Oct 25, 2019 at 9:41 AM Charlotte Toma (WhereGroup) <
>> Hello everybody,
>> I would like to know if you can increase the click tolerance for the
>> GetFeatureInfo query from QGIS Server.
>> I created some WMS and would like to change the sensitivity for point
>> based queries. I only know how to do that with Mapserver (TOLERANCE)...
>> I am looking forward to your feedback and thanks!
>> Charly
> Hi Charly,
> isn't the answer to your question in the documentation?
> https://docs.qgis.org/3.4/en/docs/user_manual/working_with_ogc/server/services.html#getfeatureinfo
> If you had any problem finding the documentation then please let us know.
>> Where2B Konferenz 2019
>> 12. Dezember 2019 in Bonn
>> where2b-conference.com
>> Charlotte Toma
>> GIS-Consultant
>> WhereGroup GmbH
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 - 24
>> Fax: +49 (0)228 / 90 90 38 - 11
>> info at wheregroup.com
>> www.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3:   www.itopen.it
> 12. Dezember 2019 in Bonnwhere2b-conference.com
> Charlotte Toma
> GIS-Consultant
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> info at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191026/1675ac0b/attachment-0001.html>
