[Qgis-user] QGIS 3.10 GeoPDF creation greyed out
Jürgen E. Fischer jef at norbit.de
Mon Oct 28 06:01:02 PDT 2019
Hi Andreas,
On Mon, 28. Oct 2019 at 11:29:25 +0100, Andreas Neumann wrote:
> Yes, 2.4.1 is too old. You need 3.0 or higher.
> Did you also try the standalone installer whether that contains the
> correct GDAL version?
That would be suprising.  The standalone is made from the same binaries.  And
as GRASS doesn't support GDAL3 yet, the main GDAL is stuck at 2.4.1 in OSGeo4W.
The QGIS nightlies however are built with the GDAL and PROJ nightlies.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191028/f46c9f0d/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191028/f46c9f0d/attachment.ksh>
