[Qgis-user] QGIS 3.10 GeoPDF creation greyed out
    Andreas Neumann
    a.neumann at carto.net
    Mon Oct 28 06:23:38 PDT 2019
HI Jürgen,
Oh - that is too bad. Do you have any clue when GRASS will be supporting
GDAL3?
It is a pity now, because several organizations in Austria and
Switzerland shuffled up quite a bit of funds to be able to support
GeoPDF and now they can't use it, because the most popular platform of
QGIS (Windows) doesn't support it.
And packaging a version of QGIS without GRASS is probably not an option
either? Would probably be an extra burden for you on managing the
packages ...
Andreas
On 2019-10-28 14:01, Jürgen E. Fischer wrote:
> Hi Andreas,
> On Mon, 28. Oct 2019 at 11:29:25 +0100, Andreas Neumann wrote:
>> Yes, 2.4.1 is too old. You need 3.0 or higher.
>> Did you also try the standalone installer whether that contains the
>> correct GDAL version?
> That would be suprising.  The standalone is made from the same binaries.  And
> as GRASS doesn't support GDAL3 yet, the main GDAL is stuck at 2.4.1 in OSGeo4W.
> The QGIS nightlies however are built with the GDAL and PROJ nightlies.
> Jürgen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191028/17c6bde2/attachment.html>
