[Qgis-user] QGIS and WFS limitations
Lars I. Nielsen, LIFA A/S
lin at LIFA.DK
Tue Oct 29 07:40:52 PDT 2019
Thanks Even.
I always thought that the QGIS client and QGIS server shared a common code base?
But if it's the server side WFS implementation that does POST, it of course doesn't mean that the WFS client side also does, although it would be a natural assumption to have both run in parallel.
And the feature request I referred to just state that it concerns "QGIS Application", which I assumed to mean the client.
Regards
Lars
-----Oprindelig meddelelse-----
Fra: Even Rouault [mailto:even.rouault at spatialys.com]
Sendt: 29. oktober 2019 15:22
Til: qgis-user at lists.osgeo.org
Cc: Lars I. Nielsen, LIFA A/S
Emne: Re: [Qgis-user] QGIS and WFS limitations
Lars,
https://issues.qgis.org/issues/6535 is about QGIS server side, and here if I understand well, you are considering QGIS client side, so completely different parts of the code
> Did the developers forget to implement WFS POST in 3.x ?
It seems https://github.com/qgis/QGIS/issues/32348 was created recently about that.
If you can add a way to reproduce your issue in that ticket (server + QGIS filter), that could be useful
Even
Spatialys - Geospatial professional services http://www.spatialys.com
