[Qgis-user] QGIS and WFS limitations
Matthias Kuhn
matthias at opengis.ch
Tue Oct 29 07:29:01 PDT 2019
Hi Lars,
Thank you for bringing that up. There has been a feature request opened
for this - or at least something very similar - recently
(https://github.com/qgis/QGIS/issues/32348.
The next step will be that someone starts working on this. It is
possible that someone will volunteer his precious time. This is unlikely
to happen if developers are put under general suspicion of being
forgetful and lazy. There is also the other possibility that someone
that has the skills and availability is contracted to work on this.
Looking forward to a constructive discussion!
Best regards
Matthias
On 10/29/19 3:11 PM, Lars I. Nielsen, LIFA A/S wrote:
> Hi list.
> We’re using QGIS 3.4.9 with WFS, and it seems like WFS calls with
> filters are being sent using GET, not POST.
> Which means that a non-trivial filter eventually generates a too long
> URL at some point. I’m currently having problems with an URL with a
> length of just 1958 characters. An URL with length 1713 characters
> appears to be working.
> I can see that the issue was implemented 6 years ago according to the
> issue tracker (Feature request #6535), so why isn’t it working
> properly now ??
> Did the developers forget to implement WFS POST in 3.x ?
> Med venlig hilsen
> GIS-konsulent, FME Certified Professional
> Geoinformatik
> Beskrivelse: Beskrivelse:
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\284x82-3741133837051347070
> *T*
> 6313 6800
> lin at lifa.dk
> *D*
> 6313 6849
> *W*
> www.lifa.dk <http://www.lifa.dk>
> *M*
> 2492 4866
> *CVR*
> 20937289
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-3019966288736195652
> <https://www.linkedin.com/company/lifa-a-s/>
> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191029/64e2855e/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191029/64e2855e/attachment.gif>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191029/64e2855e/attachment.png>
