[Qgis-user] banging my head against the QGIS wall
Tomas Straupis
tomasstraupis at gmail.com
Fri Sep 13 12:35:27 PDT 2019
2019-09-13, pn, 21:40 Alessandro Pasotti rašė:
> Also increase the logging level and if you can access a debug build set QGIS debug on.
How do you actually do that?
I have a QGIS master built with debug on (Fedora).
I can get debug output for QGIS Desktop by launching it after
setting environment variables:
QGIS_DEBUG=9
QGIS_LOG_FILE=/tmp/qgis_debug.txt
But if I add these two environment variables in apache config file
FcgidInitialEnv - debug output from server does not appear in
/tmp/qgis_debug.txt file (such file is not even created, SELinux is
switched off).
Documentation:
https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/config.html
mentions:
QGIS_SERVER_LOG_LEVEL "0"
QGIS_SERVER_LOG_STDERR "1"
but this only enables "general" messages from QGIS Server (request
parameters, time spent etc.) - I do not get say all queries actually
performed (which I get for desktop). QGIS Server is doing some
additional queries upon starting(?) which takes minutes for very large
tables and I would like to find out what exactly it is doing (as I did
for desktop).
Tomas
