[Qgis-user] banging my head against the QGIS wall
Tomas Straupis
tomasstraupis at gmail.com
Wed Sep 18 00:01:51 PDT 2019
2019-09-14, št, 01:17 Tom Vogt rašė:
> My Apache config:
> FcgidIOTimeout 120
> FcgidInitialEnv LC_ALL "en_US.UTF-8"
> FcgidInitialEnv PYTHONIOENCODING UTF-8
> FcgidInitialEnv LANG "en_US.UTF-8"
> FcgidInitialEnv QGIS_DEBUG 1
> FcgidInitialEnv QGIS_SERVER_LOG_FILE /tmp/qgis-000.log
> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
My tests on Fedora show that following gives server logs (requests,
parameters, response times):
FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1
Logs are written to /var/log/httpd/error_log. And if I add this:
FcgidInitialEnv QGIS_SERVER_LOG_FILE /tmp/qgis_server.log
logging mentioned above stops.
Could be that apache process is chrooted and therefore does not have
permission to write to such a log file. Don't know how to test that.
However the method mentioned by Jorge works:
1. Create a script with all FcgidInitialEnv taken from apache config
converted to export's like:
export QGIS_SERVER_LOG_FILE=/tmp/qgis-000.log
2. Add query string variable and project file:
export QUERY_STRING="SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities"
export QGIS_PROJECT_FILE="/var/www/wms/oracle.qgs"
3. execute qgis_mapserv.fcgi with debug on:
export QGIS_DEBUG=9
export QGIS_LOG_FILE=/tmp/qgis.log
./qgis_mapserv.fcgi
This gives both server logs as well as debug information in separate
files. I just can't see what is being executed upon *second* request
to the server process (as some "initialisation queries" are definitely
skipped - requests are processed much faster).
Tomas
