[Qgis-user] Problems with the tool: join by attributes
Jennifer Schubert
jennifer.schubert at glu.de
Tue Sep 17 01:12:50 PDT 2019
I want to spatially join points with individual values to a polygon grid.
The resulting shapefile should have a column where the values oft the points are summed up - according to the grid cell they are found in.
This simple operation works fine in QGIS 2.18 where you can click "sum" as the method of statistics.
However, the newer versions of QGIS don't have the possibility to indicate the method of statistics or I cannot find them, so I cannot get the task done with it.
Does anybody now how to perform this tool successfully in QGIS 3.8.2?
Thanks in advance
Jennifer Schubert
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190917/1909ea94/attachment.html>
