[Qgis-user] Question about Weighting Power value when running Grid-Inverse Distance to a Power
Daniel Zepeda Rivas daniel.zepeda at udc.es
Tue Sep 17 03:00:03 PDT 2019
When using the Raster -> Analysis -> Grid (Inverse Distance to a Power)
At the menu just before pressing run, can somebody please explain me the effect of the "Weighting power" option in the interpolation process?
I'm trying to make a temperature map based on points representing each weather station, containing the yearly averages values of temperature, and when moving the number from the 2 (set it by default) to 4, 6 or 10, the map changes significantly
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190917/50197d94/attachment.html>
