[Qgis-user] Question about Weighting Power value when running Grid-Inverse Distance to a Power
DelazJ delazj at gmail.com
Tue Sep 17 03:39:33 PDT 2019
Tracking information from the Help button in the algorithm dialog led me to
https://gdal.org/tutorials/gdal_grid_tut.html#inverse-distance-to-a-power
Hope that helps,
Harrissou
Le mar. 17 sept. 2019 à 12:00, Daniel Zepeda Rivas <daniel.zepeda at udc.es> a
écrit :
> When using the Raster -> Analysis -> Grid (Inverse Distance to a Power)
> At the menu just before pressing run, can somebody please explain me the
> effect of the "Weighting power" option in the interpolation process?
> I'm trying to make a temperature map based on points representing each
> weather station, containing the yearly averages values of temperature, and
> when moving the number from the 2 (set it by default) to 4, 6 or 10, the
> map changes significantly
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190917/654654fa/attachment.html>
