[Qgis-user] QGIS 3 copy style form from one attribute table to another (both no geometry) does not seem to work
Janneke van Dijk
janneke.qgis at gmail.com
Thu Sep 19 06:44:54 PDT 2019
Thanks for confirming, Matthias (and bummer - I was hoping I had
overlooked something :-) ). Will open a ticket.
Janneke
On 18/09/2019 16:38, Matthias Kuhn wrote:
> Hi Janneke,
> Sounds very much like a bug to me (or a very desirable feature,
> depending on the point of view). Can you open a ticket for that?
> Thanks a lot
> Matthias
> On 9/18/19 3:00 PM, Janneke van Dijk wrote:
>> Dear List,
>> The work around seems to be to save the style as .qml and then load
>> it for the other layer. I would still like to know if it is expected
>> that copy style does not work in this case or that this is a bug.
>> thanks,
>> Janneke
>> On 18/09/2019 15:56, Janneke van Dijk wrote:
>>> Dear List,
>>> I have prepared a drag and drop designer form with several
>>> containers, and I would like to use the same form for another table
>>> with the same structure. Both tables do not contain geometry and are
>>> layers in two different geopackage files. I thought it should be
>>> possible to click Style>copy>all on the layer containing the correct
>>> form, then Style>paste>all on the layer where I would like to have
>>> the drag and drop form. When I do it, nothing seems to happen - the
>>> form remains 'autogenerate' with all attributes listed.
>>> Should this work? Should I do something else? File a bug report? Is
>>> there a work around?
>>> Thanks for thinking along,
>>> Janneke
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
