[Qgis-user] QGIS 3 copy style form from one attribute table to another (both no geometry) does not seem to work
Matthias Kuhn matthias at opengis.ch
Wed Sep 18 06:38:36 PDT 2019
Hi Janneke,
Sounds very much like a bug to me (or a very desirable feature,
depending on the point of view). Can you open a ticket for that?
Thanks a lot
Matthias
On 9/18/19 3:00 PM, Janneke van Dijk wrote:
> Dear List,
> The work around seems to be to save the style as .qml and then load it
> for the other layer. I would still like to know if it is expected that
> copy style does not work in this case or that this is a bug.
> thanks,
> Janneke
> On 18/09/2019 15:56, Janneke van Dijk wrote:
>> Dear List,
>> I have prepared a drag and drop designer form with several
>> containers, and I would like to use the same form for another table
>> with the same structure. Both tables do not contain geometry and are
>> layers in two different geopackage files. I thought it should be
>> possible to click Style>copy>all on the layer containing the correct
>> form, then Style>paste>all on the layer where I would like to have
>> the drag and drop form. When I do it, nothing seems to happen - the
>> form remains 'autogenerate' with all attributes listed.
>> Should this work? Should I do something else? File a bug report? Is
>> there a work around?
>> Thanks for thinking along,
>> Janneke
> Qgis-user mailing list
