[Qgis-user] QGIS 3 copy style form from one attribute table to another (both no geometry) does not seem to work
    Janneke van Dijk
    janneke.qgis at gmail.com
    Wed Sep 18 06:00:33 PDT 2019
Dear List,
The work around seems to be to save the style as .qml and then load it
for the other layer. I would still like to know if it is expected that
copy style does not work in this case or that this is a bug.
thanks,
Janneke
On 18/09/2019 15:56, Janneke van Dijk wrote:
> Dear List,
> I have prepared a drag and drop designer form with several containers,
> and I would like to use the same form for another table with the same
> structure. Both tables do not contain geometry and are layers in two
> different geopackage files. I thought it should be possible to click
> Style>copy>all on the layer containing the correct form, then
> Style>paste>all on the layer where I would like to have the drag and
> drop form. When I do it, nothing seems to happen - the form remains
> 'autogenerate' with all attributes listed.
> Should this work? Should I do something else? File a bug report? Is
> there a work around?
> Thanks for thinking along,
> Janneke
