[Qgis-user] 1 to many relationship does not allow to display the many
Janneke van Dijk
janneke.qgis at gmail.com
Thu Sep 19 07:42:33 PDT 2019
Hi Harrissou,
Thanks for the quick response - indeed, I indicated the assetid which is
a unique value. That did not solve the problem, alas...
Janneke
On 19/09/2019 17:31, DelazJ wrote:
> Hi Janneke,
> Maybe you need a field that would uniquely identify the 170 asset rows
> (their primary key). You can use an ID field of your asset layer or
> construct one with row_number function?
> Regards,
> Harrissou
> Le jeu. 19 sept. 2019 à 16:10, Janneke van Dijk
> <janneke.qgis at gmail.com <mailto:janneke.qgis at gmail.com>> a écrit :
> Dear list,
> I have a parent - child relationship set up between a table
> location (1,
> the parent) and a table assets (many, the child). The location table
> contains geometry, the asset table does not. I would like to be
> able to
> display each record in the asset table with the corresponding
> geometry
> of the location table - so if there are 3 assets at a certain
> location,
> I would like to display 3 points (each with identical geometry).
> What I can do with the DB manager is:
> select location_point.geom, asset_point.assetid, location_point.fid
> from asset_point cross join location_point on
> asset_point.locationid =
> location_point.fid
> this query yields 170 records, corresponding with the number of
> records
> in the assets table. When I load as a new layer, the result is a
> table
> with 170 records, but 100 filtered (the total number of locations). I
> chose assetid to be the unique id (which it is).
> Is that expected behaviour? How else can I display all the records in
> the assets table (instead of only the 100 that are filtered now)?
> I know
> I can do it in Postgres but for my purpose now I don't want to go
> there.
> Any insights deeply appreciated!
> Janneke
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190919/e5928f4a/attachment.html>
