[Qgis-user] 1 to many relationship does not allow to display the many
DelazJ
delazj at gmail.com
Thu Sep 19 07:56:32 PDT 2019
You mean, it's the selected field in the primary key drop-down menu in DB
manager when you want to add the layer?
Le jeu. 19 sept. 2019 à 16:42, Janneke van Dijk <janneke.qgis at gmail.com> a
écrit :
> Hi Harrissou,
> Thanks for the quick response - indeed, I indicated the assetid which is a
> unique value. That did not solve the problem, alas...
> Janneke
> On 19/09/2019 17:31, DelazJ wrote:
> Hi Janneke,
> Maybe you need a field that would uniquely identify the 170 asset rows
> (their primary key). You can use an ID field of your asset layer or
> construct one with row_number function?
> Regards,
> Harrissou
> Le jeu. 19 sept. 2019 à 16:10, Janneke van Dijk <janneke.qgis at gmail.com>
> a écrit :
>> Dear list,
>> I have a parent - child relationship set up between a table location (1,
>> the parent) and a table assets (many, the child). The location table
>> contains geometry, the asset table does not. I would like to be able to
>> display each record in the asset table with the corresponding geometry
>> of the location table - so if there are 3 assets at a certain location,
>> I would like to display 3 points (each with identical geometry).
>> What I can do with the DB manager is:
>> select location_point.geom, asset_point.assetid, location_point.fid
>> from asset_point cross join location_point on asset_point.locationid =
>> location_point.fid
>> this query yields 170 records, corresponding with the number of records
>> in the assets table. When I load as a new layer, the result is a table
>> with 170 records, but 100 filtered (the total number of locations). I
>> chose assetid to be the unique id (which it is).
>> Is that expected behaviour? How else can I display all the records in
>> the assets table (instead of only the 100 that are filtered now)? I know
>> I can do it in Postgres but for my purpose now I don't want to go there.
>> Any insights deeply appreciated!
>> Janneke
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190919/2d4b072c/attachment.html>
