[Qgis-user] how to fix the raster calculator
Áron Gergely
aron.gergely at rasterra.nl
Tue Sep 24 04:00:56 PDT 2019
Hi Raymond and list,
I think your first issue may have been caused by the decimal character
in your formula not matching the locale;
Can be a point '.' or comma ','
I also use the 'high school math' methods you mentioned ;) I am not
aware of any tricks.
Would be nice to have convenience functions for abs(), max(), mean(),
stdev(), etc..
As a workaround you can use the GDAL raster calculator, I think abs()
and similar are implemented there.
If anyone is aware of any QGIS raster calculator tricks I would be eager
to learn about them as well.
Best Regards,
Aron
On 24/09/2019 12:19, Raymond Nijssen wrote:
> Hi,
> I've been using the raster calculator lately and bumped into some
> unexpected behaviour issues. They are hard to isolate but I will
> create issues
> One of the things is the creation of empty output grids, resulting in
> raster layers with a range as described earlier in this thread:
> ([-1.79769e+308 to 1.79769e+308] instead of [0 1].
> Somehow this was fixed after changing the locale (!) from NL back to
> EN. I was using a model that contained raster calculators and a python
> script running it.
> No clue what it could be, maybe parameter names being translated (I
> hope not!) or locale settings for decimal point/comma.
> Also, the names of the model parameter are like
> 'qgis:rastercalculator_4:sub_calc_sqrt', still containing the
> 'rastercalculator_4' part which can not be found or changed using the
> model editor.
> Besides, I'm wondering why very common functionality is missing in the
> raster calculator. I need abs() and max() functions and they don't
> exist. Or am I missing something?
> My solutions / work arounds using creative high school math are:
> abs(a):
> sqrt(a * a)
> or
> ((a >= 0) * a) + ((a < 0) * -1 * a)
> max(a, b):
> ((a >= b) * a) + ((a < b) * b)
> Hope someone has a clue here. Guess I'm not the only one using vector
> more often than raster...
> Kind regards,
> Raymond
> On 21-03-19 17:19, shalum HOUENOU wrote:
>> OK then
>> Maixent,
>> *De : *matteo <mailto:matteo.ghetta at gmail.com>
>> *Envoyé le :*jeudi 21 mars 2019 17:14
>> *À : *shalum HOUENOU <mailto:shalumhouenou at gmail.com>
>> *Objet :*Re: [Qgis-user] how to fix the raster calculator
>> please answer to all (so you question is forwarded also to the user
>> mailing list)
>> I think then the raster calculator has a bug. Could you please report
>> it?
>> https://issues.qgis.org/projects/qgis
>> or try to upgrade to QGIS 3.6
>> On 3/21/19 5:13 PM, shalum HOUENOU wrote:
>> > Yes I did, as it was mentionned in the training manual, section 8.3.7
>> > You have the link below :
>> https://docs.qgis.org/testing/en/docs/training_manual/rasters/terrain_analysis.html#moderate-fa-using-the-raster-calculator
>> > Maixent,
>> > *Envoyé le :*jeudi 21 mars 2019 17:07
>> > *À : *shalum HOUENOU <mailto:shalumhouenou at gmail.com>;
>> > qgis-it-user-owner at lists.osgeo.org
>> > <mailto:qgis-it-user-owner at lists.osgeo.org>
>> > Hi Maixent,
>> >> Indeed the boundaries of my output layer have Strange values
>> >> Thus the output layer is invisible.
>> >> I’ve already tried to change the max and the min value : The
>> layer is
>> >> still invisible.
>> >> What else could I do to fix it ? Any idea ?
>> > did you also set the reference layer in the algorithm UI?
>> > Matteo
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
