[Qgis-user] QGIS installation on Ubuntu 18.04
    J. M
    jimimckay at gmail.com
    Wed Sep 25 09:44:00 PDT 2019
Hi again Andre,
Okay, I did add this line: deb https://qgis.org/debian bionic main  to
etc/apt/sources.list, but I didn't know you could include 'ubuntu' there, I
thought it had to read 'debian'. Interesting about the icon for editing
source packages; do you mean it's an application within Ubuntu? I
understood it had to be manual so I didn't look for it. What is it called?
I'll try modifying the package sources again and I'll update and upgrade
once it's installed, to see if that was all it was. Should I run 'sudo
apt-get remove qgis' and 'sudo apt-get purge qgis', or is there a neater
way of ensuring all QGIS and GRASS packages are removed?
Thanks a lot everyone, I'll get there...
Jimi.
On Wed, Sep 25, 2019 at 5:20 PM Andre Joost <andre+joost at nurfuerspam.de>
wrote:
> Am 25.09.19 um 17:10 schrieb Andre Joost:
> > I don't see any attempt to contact https://qgis.org. So you get only the
> > version from the ubuntu repository.
> > Did you add "deb https://qgis.org/ubuntu bionic main" to your sources?
> > You don't have to edit the sources file, there is an icon in your menu
> > for editing package sources.
> ... and run "sudo apt-get update" afterwards. In your screenshots, you
> ran upgrade twice, but not update?
> HTH
> Andre Joost
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190925/86f7c371/attachment.html>
