[Qgis-user] QGIS installation on Ubuntu 18.04
    J. M
    jimimckay at gmail.com
    Thu Sep 26 05:43:07 PDT 2019
I've done it! I followed Andre's last piece of advice and modified the
following line in etc/apt/sources.list: deb https://qgis.org/debian bionic
main, changing *debian* to *ubuntu*, and it downloaded Zanzibar instead of
Las Palmas! I still wouldn't know how to install a previous version, so it
would be interesting to know how to do that...
Many thanks to this fantastic community!
Jimi.
On Wed, Sep 25, 2019 at 6:44 PM J. M <jimimckay at gmail.com> wrote:
> Hi again Andre,
> Okay, I did add this line: deb https://qgis.org/debian bionic main  to
> etc/apt/sources.list, but I didn't know you could include 'ubuntu' there, I
> thought it had to read 'debian'. Interesting about the icon for editing
> source packages; do you mean it's an application within Ubuntu? I
> understood it had to be manual so I didn't look for it. What is it called?
> I'll try modifying the package sources again and I'll update and upgrade
> once it's installed, to see if that was all it was. Should I run 'sudo
> apt-get remove qgis' and 'sudo apt-get purge qgis', or is there a neater
> way of ensuring all QGIS and GRASS packages are removed?
> Thanks a lot everyone, I'll get there...
> Jimi.
> On Wed, Sep 25, 2019 at 5:20 PM Andre Joost <andre+joost at nurfuerspam.de>
> wrote:
>> Am 25.09.19 um 17:10 schrieb Andre Joost:
>> > I don't see any attempt to contact https://qgis.org. So you get only
>> the
>> > version from the ubuntu repository.
>> > Did you add "deb https://qgis.org/ubuntu bionic main" to your sources?
>> > You don't have to edit the sources file, there is an icon in your menu
>> > for editing package sources.
>> ... and run "sudo apt-get update" afterwards. In your screenshots, you
>> ran upgrade twice, but not update?
>> HTH
>> Andre Joost
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190926/b05d3d9d/attachment.html>
